DLL Problem, please help
The image is not loading - perhaps you can explain the problem some other way?
Edit : Maybe you should make sure the link is accurate - looks like it was parsed by the forum software somehow. :)
it says : The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occured because the DLL C:\WINDOWS\system32\HHCTRL.COX was occupied an address range reserver for windows system DLLs.The vendor supplying the DLL should be contacted for a new DLL.
