123Eish
Hi Everyone,
Does 5G work during load shedding? Basically asking if the 5G towers have backup power.
If it does what is the cheapest way to keep my 5G Outdoor modem running when the power goes out?
It uses a poe injector so those cheaper fibre router UPS/battery pack solutions commonly found on Takealot won't work.
I do not want to spend 5k plus for an inverter/battery setup when I only need the router running.
