I have an N80, and previously to that I had a N70 which was stollen
Ok, The Nokia N80. I keep my firmware up to date, you can do this by downloading the Nokia Software Updater from the Nokia website. Nokia is now updating all standard N80's to N80ie, meaning you have a new Download folder filled with new apps, but the best app is deffinitly VOIP, i use the truphone services via my wlan.
Appwise, S60v3 still doesnt have the abundence of applications such as the previous versions of S60 devices.
I use these proggies: (when reg needed I have keys
Mxit
IM++
Handy Clock
Handy Expenses
Mig33
and a few games.
I have found no problems with these proggies and the never has my N80 hung on me so far
There is one precaution you should take with multitasking, is when you have opened ram hungry apps or many apps, when the phone needs the memory it will close the apps using all the resourses.
Battery life is a bit of a problem, medium to heavy use means you will be recharging every night, but the new firmware helps with making the battery last.
Imo this phone is deffinintly better then the N70,N71,N72,N90,N91.
Now the N73 is very simalar, just change in looks, size, different shutter for the camera, and a larger screen (but the N80 screen is so much more crisp)
So the N73vN80 war is very hard to find a winner, if you want wlan and a slider then the N80 wins.
PM me if you want to download a nice app pack from another site
Silent_Bob
EDIT:
I AM THE #1 N SERIES FAN!
