Masquerade
- Aug 15, 2012
Hi guys.
So about a month and a half ago I had my line installed. It's a 6mb line and it worked perfectly up until last week Wednesday.
Ever since Wednesday my line will sync fine. It would even connect to my ISP, albeit taking a bit longer. This is the strange part, I can't do anything. I can't browse, I can't connect any applications. I could ping websites and even do tracert, and got quite poor results from it. On Wednesday night at 10 it started working again, but only for 2 hours. After that the packet loss started, and it stopped working completely at 12-ish.
Now since then it's gotten progressively worse. First I couldn't even ping websites anymore. Now I can't even connect to the ISP, even though my line syncs fine.
Now I've had 3 techies come out. The first two only tested it from the exchange, and basically closed the fault saying it's been resolved and the line is free from any defects. The third one actually came to my house, and tested it with his router and computer as well. He couldn't even sync. He called me later and said I should try and see if I can connect. And he'll call me again later to find out if it's working. He never did. He seemed pretty shocked that it would sync and connect to the ISP, but not receive or send any date.
So do you guys have any idea what might be causing this?
Thanks in advance
Thanks in advance
