Olla peeps!
I'm pulling my hear atm.
I have a 4Mb line, and the past 4 weeks I'm unable to play any COD, latency to high.
I logged a call with telkom, two days later, received sms, call resolved. Tested again, and logged a call again, two days later, resolved....now what you guys think I can do.
I tested my account with webafrica, afrihost and axxess....all same results.
Currently have a D-Link 2740U router, I tested the line with a USB DSL modem as well.
I tested it from my pc as well my laptop, same results.....surely the problem is not on my side then? The problem seems to not always be there, played a while last night and suddenly started lagging again. Tonight....no chance!
Here some info and tests
SNR Margin (0.1 dB): 204 (20.4dB) 120 (12dB)
Attenuation (0.1 dB): 180 (18dB) 90 (9dB)
Output Power (0.1 dBm): -37 43
Attainable Rate (Kbps): 9728 1064
Rate (Kbps): 3072 512 (used to sync at 4Mb) :wtf:
Local Speed Test
http://www.speedtest.net/result/1098677316.png
http://www.speedtest.net/result/1098681004.png
International Speed Test (London - GB)
http://www.speedtest.net/result/1098725281.png
Local Pingtest
http://www.pingtest.net/result/31568085.png
http://www.pingtest.net/result/31568376.png
Any help would be appreciated.
Local Speed Test
Local Pingtest
