MisterBigglesworth
Hi everyone,
Ok before I get to the above subject, need to give a kwik background. TV got hit by lighning. Got a new TV and reception is fuzzy, not good at all on all channels incl DSTV. So went to multichoice for them to check my single view DSTV decoder (non pvr).
So back to the subject...I noticed when they tested it, they plugged in the red/white/yellow connectors (like you would for a dvd player), and tested the reception. All was fine. Then they unplugged the red/white/yellow connectors and plugged in their antenna etc. That worked too, so the decoder is fine and seems the lighting knocked out something on external aerial or dish. I digress though...as usual.
What I noticed when they were testing the decoder is the reception / quality of the picture was much better when they connected via the red/white/yellow connectors compared to the antenna connector. I had no idea this could be done? Is it as simple as going home and plugging in my spare dvd cable from the decoder into the TV?
If it is that simple...Im gonna be irritated cos been watching TV via the antenna in the decoder since always?
Chers
Chers
