superskully
So this is not actually a holiday home but i rather call it that then explaining further.
I have a HD PVR2 and DSD110 (extraview).
At this other home, it has a DSTV signal - just 1 cable though.
So, can i use the DSD as is (programmed for extraview though it may look for the heartbeat).
Otherwise, can i take the HD smartcard and insert into the DSD (hoping this will kill off the search for the heartbeat).
If no to the above:
Can i take the PVR, only LNB as mentioned - would it work?
And i dont want to ask Multichoice (maybe they charge extra), or upgrade the other home to dual LNB...
Basically i dont want to pay anything.
Can any of this be done.
If no to the above:
