Sackboy
http://forum.dstv.com/showpost.php?p=23159&postcount=8Dear xxxxxxxx
When you registered on the forum you agreed to abide by our terms and conditions.
Your posts have been removed as it contravenes the terms and conditions. It is also not in the spirit of the forum.
The forum is transparent and we do not remove posts, even if they are critical. However your posts are defamotory in nature.
You are welcome to send us comments that are constructive and not inciteful
Regards
MC Fathima
Do you believe it??
