Get a split box and add a normal arial to the top TV.
So if you don't have an aerial, how are you going to receive terrestrial broadcast?
Aerial or "Dualview"
If I'm not mistaken, I have one of those lying at home, which isn't in use.
I honestly fail to see how this will help you? Unless you have a dual view decoder, your single view decoder has only one output, unless you also have a terestrial antenna in place.
Are you wanting to get SABC etc seperately from DSTV?
