I.am.Sam
Hi
Is anyone using slyguy on kodi 19.5 & working
yes everyone that paid for it is working ...
Hi
HSam. Please assist. Do we need to pay now for slyguy? Whats the story here?i
Hi Sam
Stop being facetious can you simply answer the question
i charge per reply ....
I understand. noticed the problem. Will be fixed soon
Ematic issue solved. Uninstall DStv app to factory version 1. Try open DStv from main menu and it will automatically give you the option of updating. This will install version 2.4.5. You will then be required to type the activation code into now.dstv.com/tv and it sorts the problem out
I have the same issue but what works for me is to have the Dstv app on your phone as well and Mi box both apps signed in.Hi guys.
I have a xiaomi mibox 3 which I use to stream dstv now. The past days though it seems to be quite problematic.
If I choose a channel the screen just goes blank and nothing loads. Even if I restart the device or reinstall the app the same thing seems to happen.
Is anyone else having the same problem?
