DSTV on Demand help required
tom110584
Pinetown, Durban
hi there,
i recently started using dstv on demand and would like to know if there is any way to locate the files you download and play them on a pc media player like VLC. also, how do you stream the shows/movies to your TV? can you do it via a program like ps3 media server?
thanks!
The files are only playable using the OnDemand player - nothing else will work and you can also not stream it via other software. A similar question was asked on the DSTV forums.
