Depends on the decoder model. Many models have software bugs that necessitate a reboot to function correctly. Decoder model, signal strength numbers, frequency of this problem, and so forth would be required to begin to troubleshoot the issue. If it never gives you programme guide data then it is likely a signal/lnb/dish issue. Test it as a friend's place or at your local MC office. Does it still happen?
