Dstv SD two points approix cost
Lino
I am back
So I want to get dstv SD but need a decoder and installed to two points. What cost am I looking at
Sent from my u8800 using MyBroadband Android App
Anyone
R599 for a 1131 decoder fully installed to a single point. Installer will charge R150-R350 to run a cable to the second point (depends on distance etc). So, probably under a grand.
Assuming you need a dish & full installation use the R599 special which includes decoder & installation to one point. They shouldn't charge you more then R200 to run a RF cable to another room unless its a fair distance
edit: no replies all day & then QT & I say the same thing within a few secs :p
:confused:
What else do you want? What Smurf and me said, is the way to go... Smurf actually knows what he is talking about in this section of the forum... and I try too.
Lino QT and Smurf are quite correct, will be the cheapest and easiest way to do it.
:confused:
Think you typed that the wrong way around ;)
Lino, no-one else could possibly compete with our replies so it just wasn't worth their effort
Your other option is to call Gerrit if you live in the Northern Cape
