DuracellBunny
Last update on the extension was that they wanted to it to be a metal conduit and it must be bonded to earth. But this publication was put up and removed. Hell if they made that enforced I assume nearly 99% of installs with solar will fall under non compliant but I really doubt they will push that forward. The Rigid PVC conduits are just find as long as they properly secured and correctly rated to handle the power from the panels.What is the SANS appropriate conduit/trunking to use when looking at PV DC cables running outside -> inside the house via the ceiling-space down a garage wall?
