DVD DL. Problems writing on Pc
Peder
Hobbit
Pretoria South Africa
Hi Guys,
I made 7 DVD DL's (dual-layers)
Wrote 5 of them on a Mac, and 2 of them on a PC, now the ones i wrote on the pc won't read on a DVD Player :(
But the mac ones will, my problem is i have to make almost 120 DVD's but i don't own the mac, its on lend from someone else, anyone got any ideas as to how i can make the PC write properly?
Peder
When you are copying it with nero are you using nero recode or creating a data dvd, its possibly not working because you are creating a data dvd, use nero recode or select the option to burn dvd files to disk
Ok, uhm, try clicking copy dvd in nero and then choosing how many copies you want, put the successfully burned dvd in and copy it to blank disks that way.
