E220 and 8.ta possible?
AstroTurf
Lucky Shot
As with the title.
I have also tried the sim on a 3g router without success (Dlink DIR-455U).
APN: internet
Account name 8.ta
Dialed Number *99#
Any Suggestions?
Is the 8.ta rep still around?
Tried calling the number as well for support, no luck, long beep. (081183)
As with the title.
APN: internet
Account name 8.ta
Dialed Number *99#
Any Suggestions?
Hi the E220 works with the 8ta SIM with the default Mobile Partner.
Please try the 8ta Connect that you can download here http://www.8ta.com/downloads/
Thank you
Heya!
I'm happily using the 8ta 2+1GB Promo on my firmware-modded Vodaphone Huawei E220 (Firmware modded to unlock being Vodacom only, and to unlock the 8MB for lols)
Ignoring my horrifically low signal (-105dBm), I'm using MDMA, and my max transfer speed so far is at 305kb/s, although normally average 200+ local.
As 8.ta towers are 900MHz, you'll only ever be able to roam on MTN for HSDPA when using 8.ta.
Nope, I have 8ta 3G (65502) on a receiver that only supports 2100MHz UMTS ! This is on a non-roaming 8ta data SIM (2+1).
I am sure that the E220 would work here.
I've used 8.ta on the E220 (mobile partner interface) as well as on the newer E1820.
Both works very well, the E1820 gives a big increase in speed though :D
