e220 problems related to pppd error 16
bmeagle
Centurion
So after fixing my win related e220 issues:
http://mybroadband.co.za/vb/showthread.php?t=102590
my linux related issues still remain.
Using tazztux's wvdial I keep on getting a pppd 16 error modem hang up.
So I enabled the debug option in /etc/ppp/peers/wvdial, here are the results:
Jan 25 21:09:58 localhost pppd[4314]: pppd 2.4.4 started by root, uid 0
Jan 25 21:09:58 localhost pppd[4314]: using channel 3
Jan 25 21:09:58 localhost pppd[4314]: Using interface ppp0
Jan 25 21:09:58 localhost pppd[4314]: Connect: ppp0 <--> /dev/ttyUSB0
Jan 25 21:09:58 localhost pppd[4314]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x2375472b> <pcomp> <accomp>]
Jan 25 21:09:58 localhost pppd[4314]: rcvd [LCP ConfReq id=0x1c <asyncmap 0x0> <auth chap MD5> <magic 0xe168df> <pcomp> <accomp>]
Jan 25 21:09:58 localhost pppd[4314]: sent [LCP ConfAck id=0x1c <asyncmap 0x0> <auth chap MD5> <magic 0xe168df> <pcomp> <accomp>]
Jan 25 21:09:58 localhost pppd[4314]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x2375472b> <pcomp> <accomp>]
Jan 25 21:09:58 localhost pppd[4314]: rcvd [LCP DiscReq id=0x1d magic=0xe168df]
Jan 25 21:09:58 localhost pppd[4314]: rcvd [CHAP Challenge id=0x1 <24ac7c16047b0953326e6b933ae00f72>, name = "UMTS_CHAP_SRVR"]
Jan 25 21:09:58 localhost pppd[4314]: sent [CHAP Response id=0x1 <acc0ab60fb56f1005a3dfcff43d2bd4e>, name = "username"]
Jan 25 21:09:58 localhost pppd[4314]: rcvd [CHAP Success id=0x1 ""]
Jan 25 21:09:58 localhost pppd[4314]: CHAP authentication succeeded
Jan 25 21:09:58 localhost pppd[4314]: sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Jan 25 21:09:59 localhost pppd[4314]: Modem hangup
Jan 25 21:09:59 localhost pppd[4314]: Connection terminated.
Jan 25 21:09:59 localhost pppd[4314]: Exit.
Jan 25 21:10:19 localhost pppd[4333]: pppd 2.4.4 started by root, uid 0
Jan 25 21:10:19 localhost pppd[4333]: using channel 4
Jan 25 21:10:19 localhost pppd[4333]: Using interface ppp0
Jan 25 21:10:19 localhost pppd[4333]: Connect: ppp0 <--> /dev/ttyUSB0
Jan 25 21:10:19 localhost pppd[4333]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5999f654> <pcomp> <accomp>]
Jan 25 21:10:19 localhost pppd[4333]: rcvd [LCP ConfReq id=0x1e <asyncmap 0x0> <auth chap MD5> <magic 0xe1bad9> <pcomp> <accomp>]
Jan 25 21:10:19 localhost pppd[4333]: sent [LCP ConfAck id=0x1e <asyncmap 0x0> <auth chap MD5> <magic 0xe1bad9> <pcomp> <accomp>]
Jan 25 21:10:19 localhost pppd[4333]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x5999f654> <pcomp> <accomp>]
Jan 25 21:10:19 localhost pppd[4333]: rcvd [LCP DiscReq id=0x1f magic=0xe1bad9]
Jan 25 21:10:19 localhost pppd[4333]: rcvd [CHAP Challenge id=0x1 <563a4a70b21d3c190e9ec1b968087056>, name = "UMTS_CHAP_SRVR"]
Jan 25 21:10:19 localhost pppd[4333]: sent [CHAP Response id=0x1 <ce9ca067dc5832b1e6779b5fc267399d>, name = "username"]
Jan 25 21:10:19 localhost pppd[4333]: rcvd [CHAP Success id=0x1 ""]
Jan 25 21:10:19 localhost pppd[4333]: CHAP authentication succeeded
Jan 25 21:10:19 localhost pppd[4333]: sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Jan 25 21:10:20 localhost pppd[4333]: Modem hangup
Jan 25 21:10:20 localhost pppd[4333]: Connection terminated.
Jan 25 21:10:20 localhost pppd[4333]: Exit.
Now I recall editing some options in my kernel related to pppd (2.6.21-r4) which probably contribe to my woes! I suspect my kernel pppd setup.
What is needed in pppd options in my kernel or what is the problem?
Thanx
bmeagle
