I have been experiencing some strange things with my my E220 wireless modem when used with a Vodacom sim.
After changing the dashboard to Mobile Partner, it worked very well with my prepaid Vodacom card and data bundles.
Recently I have had trouble with the modem/software not finding a network with the Vodacom card installed, although the same card works fine in an E620 pc card modem, and in 3 different cellphones.
My Virgin prepaid card is fine in the E220 (but only gets EDGE connections).
MTN prepaid sim also works fine.
I may have to go with this, although the Vodacom system was working well, with a [reported] 3.6m connection.
I believe Vodacom has the best HSDPA coverage.
Pricing is about the same as MTN (38c p/mb on a 500 mb bundle)
Virgin is the slowest with only EDGE, and a bit more costly at 50c p/mb ... BUT they are flexible as there is no need to buy & set up a data bundle ... (which is a mercy, with their support).
Any comments welcomed.
Regards
Richard
Regards
Richard
