E367 3G modem connection problems
charlh
Tzaneen
I have an E367 modem from MTN and I use it occasionally on my PC (win 7 Ultimate) if I have a problem with my router. Lately if I try to use it, it connects to the internet, but there is no throughput. (That is with 3 different sim cards). Yesterday I played around with the settings and changed it from the default NDIS to RAS. Then it worked perfectly. But as soon as I changed back to NDIS it gave the same problem again.
On my Laptop (win 8SL) it works 100% on either of the 2 settings.
The network settings for the modem are on the default settings (dynamic IP etc)
Where do I start looking?
I must add, I have 2 other ZTE modems which give the same problem, so it must be a setting on the PC only...
Drivers problem. Besides, I don't use NDIS on this modem, as MDMA gives inflated statistics for data usage.
On the side note, do you unplug modem before changing SIM card? Important to do so!
I have tried uninstalling and re-installing the drivers. And yes, I do unplug it before changing the sim. In fact it is unplugged 95% of the time as I normally use my 3g router for internet. I got an Afrihost sim today, and it does exactly the same. Only get throughput on RAS. I'm sure it's a network setting, but what/where? :mad:
Check that the NDIS connection is set to obtain its IP and DNS settings automatically.
Those settings are correct....
I can always take a shortcut and do a system recovery, but that takes all the fun out of everything ;)
Please you post the output of 'ipconfig /all' while connected with RAS and while connected with NDIS.
Edit: Also the output of 'route print'.
See:
http://mybroadband.co.za/vb/showthread.php/590043
Thanks Ginggs. Will post that tonight when I'm back at home. I seem to remember that client for microsoft networks and printer and file sharing is enabled on my modem settings... Will check that too. BTW my problem is on Win 7. On Win 8 it works 100%.
NDIS
Windows IP Configuration
Host Name . . . . . . . . . . . . : Charl_PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Mobile Broadband adapter Mobile Broadband Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : HUAWEI Mobile Connect - 3G Network Card
Physical Address. . . . . . . . . : 00-1E-10-1F-18-38
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 105.208.140.21(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.252
Default Gateway . . . . . . . . . : 105.208.140.22
DNS Servers . . . . . . . . . . . : 196.7.7.7
196.7.8.9
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek RTL8168D/8111D Family PCI-E Gigab
it Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : D0-27-88-33-7A-F4
IPv4 Address. . . . . . . . . . . : 192.168.1.150(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.200
DNS Servers . . . . . . . . . . . : 192.168.1.200
Ethernet adapter VirtualBox Host-Only Network:
Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
Physical Address. . . . . . . . . : 08-00-27-00-38-84
Link-local IPv6 Address . . . . . : fe80::e88f:2f37:3569:c906%19(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.56.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 520618023
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-0C-89-55-D0-27-88-33-7A-F4
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{821690F3-1DE4-45C5-8C72-6FEA548510EF}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{31071B0F-E603-485F-AD3D-064877949979}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{961D2BD3-4AC3-4AC7-AF66-F94EDA267555}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
IPv6 Address. . . . . . . . . . . : 2002:69d0:8c15::69d0:8c15(Preferred)
196.7.8.9
NetBIOS over Tcpip. . . . . . . . : Disabled
NDIS
route print
Interface List
22...00 1e 10 1f 18 38 ......HUAWEI Mobile Connect - 3G Network Card
11...d0 27 88 33 7a f4 ......Realtek RTL8168D/8111D Family PCI-E Gigabit Ethern
et NIC (NDIS 6.20)
19...08 00 27 00 38 84 ......VirtualBox Host-Only Ethernet Adapter
1...........................Software Loopback Interface 1
20...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
16...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
21...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
12...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
13...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter #2
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.200 192.168.1.150 276
0.0.0.0 0.0.0.0 105.208.140.22 105.208.140.21 286
105.208.140.20 255.255.255.252 On-link 105.208.140.21 286
105.208.140.21 255.255.255.255 On-link 105.208.140.21 286
105.208.140.23 255.255.255.255 On-link 105.208.140.21 286
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.150 276
192.168.1.150 255.255.255.255 On-link 192.168.1.150 276
192.168.1.255 255.255.255.255 On-link 192.168.1.150 276
192.168.56.0 255.255.255.0 On-link 192.168.56.1 276
192.168.56.1 255.255.255.255 On-link 192.168.56.1 276
192.168.56.255 255.255.255.255 On-link 192.168.56.1 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.56.1 276
224.0.0.0 240.0.0.0 On-link 192.168.1.150 276
224.0.0.0 240.0.0.0 On-link 105.208.140.21 286
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.56.1 276
255.255.255.255 255.255.255.255 On-link 192.168.1.150 276
255.255.255.255 255.255.255.255 On-link 105.208.140.21 286
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 192.168.1.200 Default
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
13 1030 2002::/16 On-link
13 286 2002:69d0:8c15::/128 On-link
13 286 2002:69d0:8c15::69d0:8c15/128
On-link
19 276 fe80::/64 On-link
19 276 fe80::e88f:2f37:3569:c906/128
On-link
1 306 ff00::/8 On-link
19 276 ff00::/8 On-link
Persistent Routes:
None
RAS
PPP adapter Afrihost:
Description . . . . . . . . . . . : Afrihost
IPv4 Address. . . . . . . . . . . : 105.208.250.165(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
196.7.8.9
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
IPv6 Address. . . . . . . . . . . : 2002:69d0:faa5::69d0:faa5(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
196.7.8.9
Tunnel adapter isatap.{EEF070AB-9AAA-46A3-9D97-16206553FA05}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Route print RAS
Interface List
32...........................Afrihost
et NIC (NDIS 6.20)
24...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.200 192.168.1.150 4501
0.0.0.0 0.0.0.0 On-link 105.208.250.165 26
105.208.250.165 255.255.255.255 On-link 105.208.250.165 281
127.0.0.0 255.0.0.0 On-link 127.0.0.1 4531
127.0.0.1 255.255.255.255 On-link 127.0.0.1 4531
127.255.255.255 255.255.255.255 On-link 127.0.0.1 4531
192.168.1.0 255.255.255.0 On-link 192.168.1.150 4501
192.168.1.150 255.255.255.255 On-link 192.168.1.150 4501
192.168.1.255 255.255.255.255 On-link 192.168.1.150 4501
192.168.56.0 255.255.255.0 On-link 192.168.56.1 4501
192.168.56.1 255.255.255.255 On-link 192.168.56.1 4501
192.168.56.255 255.255.255.255 On-link 192.168.56.1 4501
224.0.0.0 240.0.0.0 On-link 127.0.0.1 4531
224.0.0.0 240.0.0.0 On-link 192.168.56.1 4502
224.0.0.0 240.0.0.0 On-link 192.168.1.150 4502
224.0.0.0 240.0.0.0 On-link 105.208.250.165 26
255.255.255.255 255.255.255.255 On-link 127.0.0.1 4531
255.255.255.255 255.255.255.255 On-link 192.168.56.1 4501
255.255.255.255 255.255.255.255 On-link 192.168.1.150 4501
255.255.255.255 255.255.255.255 On-link 105.208.250.165 281
Persistent Routes:
IPv6 Route Table
Active Routes:
13 1130 ::/0 2002:c058:6301::c058:6301
13 286 2002:69d0:faa5::/128 On-link
13 286 2002:69d0:faa5::69d0:faa5/128
On-link
On-link
Persistent Routes:
None
I also then disabled my lan card in the BIOS, and then the modem worked on both NDIS and RAS. However the RAS was much faster than NDIS.
After I enabled it again, the same problem started again.
NDIS
route print
IPv4 Route Table
Active Routes:
There's your problem. Your LAN interface's default route needs to have a higher metric than your 3G modem's default route.
Try changing it from 276 to 296.
Thank you very much Ginggs for your trouble.
So in other words I must then just change it in the tcp/ip settings from automatic to 296?
Will try this tonight when I'm back home
Ginggs you damn genius you! (Pity there's no icon for a beer :D)
Thanks. I'm connected with NDIS as I type!
Now if only MTN would do something about the signal...
