E46 Crank shaft sensor problem
This is what it looks like, myabe print it out and show the guys at BMW and they will know what you mean?
Finally someone managed to get a decent picture of it...
I only had black and white line drawings of it, and unless you knew what you were dealing with they made no sense...
I phoned Bmw to ask howmuch does the crank sensor cost. I didnt tell the guy whats the problem. Without me explaining he described the problem perfectly and asked if thats the reason i need the sensor. He also told me its a very common problem and that he always has lots in stock because they sell so many, so availability wont be an issue. Check out e46fanatics.com, thats where i figured what the problem was. I also did a recent trip of abt 2000km and no cut outs.
Managed to find a REALOEM sketch on the web of the flux capacitor with the part number given above just so you know what you are looking for.
Fxit_man - dude, stop bombarding us with this wayward pics of the flux capacitor...its not the problem!
Now, get us a pic of the REAL problem - ze Crankshaft sensor!
Won't the REAL problem please stand up, please stand up, please stand up - (Crankshaft sensor rapping) Coz I'm Crank Sensor Yes I'm the REAL Problem all these other Flux sensors are just imitating, so won't the REAL problem please stand up, please stand up, please stand up!
Do you own an E46 Alfaholic?
How would you know that its not the Flux Capacitor?
I own an e46 and im telling u its the crank sensor!
+ a gazillion
i have a e46 325ci
these particular models have 2 flux capacitors - front and back, something to do with weight distrubution
its the flux capacitor man just replace it already
Damn straight..... and the front and rear ones need to be aligned as well.. otherwise it causes ALL sorts of chaos with the car.
Well crank sensor sorted my problem out. U 2 can go on and on and on and on about flux whatever. As long as im sorted i couldnt care less :-)
true
it might not need to be replaced, just ask them to check if its aligned
5min job, usually if they cool the dealerships dont charge for this sort of thing
LOL - I don't need to own an e46 to know that this is the usual symptoms with the crank sensor dude...But who's goign to be wrong when guy actualy fixesses the problem...
Team Alfaholic/rezabz or team Toxicbunny/Rodga/Fxit_man...lol
o well good then
but im afraid it might just be a temp fix
these problems seem to rear its ugly head from time to time
And thats our team song. Hahaha
