E6650 & P6N Overclock help....
xcalibur
Pretoria
These are my current specs:
MSI P6N Sli Platinum
E6550 core 2 duo
Transcend DDR2 800
These are my current overclock settings:
Rated FSB: 1900
DRAM: 475 (Running 1:1)
Multiplier: 7x
CPU Voltage: +0.0250
RAM Voltage: 2.0v
NB Voltage: 1.3v
SB Voltage: 1.5v
Do not seem to be able to change my multiplier. 2 Settings available: 6X and 7X. Resulting CPU mhz is 3325.
How can I better on this? Where/what do i need to tweak?
um, that's an insane fsb you running there!!!
and which is it. the E6650 or the E6550?
but I assume it's the E6650 because of the x7 multiplier...
It is to my understanding that you get a minimum of x6 multiplier and on that cpu, you get a max of x7...
I guess it wasn't much of an overclocker since you need an incredibly high fsb!
Sorry. Typo in the title. Its the E6550 @ 2.3ghz.
1900 is a pretty insane FSB, but somehow i'm unable to increase the CPU ratio in the BIOS above 7x. It only gives me the 2 options. Is there a way of overriding this somehow to unlock the multiplier setting in my BIOS?
The PC is pretty stable, even while running at these speeds. I was very amazed that I was able to maintain a 1:1 FSB:DRAM ratio at those speeds. If I can unlock the multiplier I'll drop them, as I dont have adequite cooling for running my CPU @ 3.8 or above.
