Edenvale ADSL problems
Axe
Edenvale, Gauteng
ADSL Connection Drops and cannot reconnect for a few hours (normally about 5 to 8). Router Line Status shows disconnected and sync speeds are zero. I phone and report the error and by the time the technician arrives (typically the next day) the connection is restored and he tells me there is no problem on the line.
Phone number: 011 524 xxxx
ADSL line speed: 2Mbps
ISP name: Afrihost 2Mbps Uncapped
Tracing route to telkom.co.za [196.43.22.222]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.3
2 9 ms 9 ms 8 ms 105-236-1-193-esr-lo.mtnbusiness.co.za [105.236.1.193]
3 10 ms 9 ms 12 ms ipc-recieve-jh-2a.za.mtnbusiness.net [41.181.178.17]
4 11 ms 9 ms 9 ms qux-jh-dca-2.za-b.za.mtnbusiness.net [41.181.165.115]
5 22 ms 10 ms 10 ms jh-dca-2.za--qux-b.za.mtnbusiness.net [41.181.165.114]
6 10 ms 10 ms 10 ms 41.181.139.109
7 12 ms 12 ms 13 ms rrba-ip-se-2-wan.telkom-ipnet.co.za [196.25.58.17]
8 12 ms 12 ms 11 ms 196.43.25.137
9 13 ms 11 ms 12 ms 196.43.39.162
10 13 ms 12 ms 11 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
11 15 ms 15 ms 14 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.34]
12 18 ms 17 ms 16 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
UpstreamDownstream
Current Rate (Kbps)5122048
Max Rate (Kbps)9963648
SNR Margin (dB)1913.8
Line Attenuation (dB)26.547.8
