Is this a hardware differentiation on a cellphone or software?
That is correct
Which part, the hardware or the software?
I am going to assume the hardware.
Normally hardware, especially between GSM (GPRS/EDGE), 3G and HSDPA. But within a 'family' (say HSDPA) you might be lucky if the manufacturer already put the hardware in but not yet the firmware to enable the higher speeds.
Some of the data cards coming out now have support built in to be upgraded to higher speeds.
Thanks V3G. Was just wondering if it was at all possible to upgrade a Edge/3G capable phone to HSDPA.
