Hobbit
I have been connecting to the Vodacom EDGE service from home using a SAMBA 75 USB modem for about a month and speed seems a bit slow. Using the Vodacom speed test I never get better than 83 kbps down and sometimes much less... up is pretty stable at 24 kbps. Modem connects and suggests that 230 kbps should be possible.
Signal strength is always good at better than 70%. Name of the tower that I connect to has recently changed to "Outdoor" from "Water Reservoir" but the speed has not altered.
Am I being unrealistic in expecting better speeds? On the positive side the connection is stable and have only lost connection for a couple of hours one morning in the last month.
