There are a few points people should watch out for when purchasing a generator:
1. Ask if the rating is at sea level or altitude. You should derate the gen output by 10-15% for Highveld conditions
2. Ask if the noise level in dB is at full-load or no-load (idle). The following dB values can be used as a guide
60 - Conversational speech
70- Business office
80 - Noisy traffic corner
90 - Heavy truck
100 - Very loud classical music
3. Also note that even on very high-end 3000rpm petrol gens (less than 6kVA), expected life is maximum 2000 hours (with proper maintenance). I have seen expected life values of 500-1000 hrs for low cost petrol gens. I would probably be cheaper to replace the gen than to have it fixed. Diesel 3000rpm should get between 2000-5000 hours before a major overhaul. 1500rpm diesel should get at 10000hrs before a major overhaul. It should be noted that the 3000prm are specified for emergency power and not standby or continuous power applications
I think there are sales people out there who are not informing the public correctly of their purchases and this could cost people in the long run. I have some units being sold with 2-4 month warrantees. The best thing is make sure of the guarantee/warrantee conditions (make sure it 1 or even 2 years), check the exclusions (running a stove etc) and make sure that spare parts etc are available
70- Business office
90 - Heavy truck
