Error 619 - help... huawei e170
AgentSmithZA
The Windy City
Hi,
Just got my huawei e170, and prepaid sim and added a bundle.
Tried to go online but no luck, if i try in in my phone, it connects.
I get fairly good signal.
My normal sim card works without bundle...
How long does it take before it should work?
Webyep
just phoned support, and a guy run through everything and he doesn't know the problem.
I'm sure its something specific needs to be activated, but he says hsdpa is enabled.
Well, I phoned support again and got put through to Vodacoms Dedicated Broadband call centre.
Explained the situation, got asked for my cell number. Two minutes later and HSDPA is up and running.
Great support!
HI webyep
Glad they sorted you out.
Regards
VodacomData
