peterhundermark
- Feb 6, 2013
Hi,
I've searched the existing threads and could not find help for my problem, so am writing this new post.
I have a dual gate system with two ET500 motors. One recently would not close properly. I checked for rolling resistance manually (with pinion disengaged), but could feel anything or detect a difference between the two. I noticed the battery negative terminal and connector were very corroded. In removing the connector, I managed to break the negative terminal right off the battery. Now with a brand new battery bought today, plus a new connector properly crimped onto the black wire, I tried again.
Now this gate will not operate at all (no difference whether on AC or battery). The system accepts the command from the remote (also from the manual activation button on the PC board with all the normal beeps (different on AC vs DC) and I can hear a relay engage (a soft click), but the motor just does not operate. I can spin the motor manually by turning the exposed wheel at the top, so it is not seized. In this state if I operate the button or remote again I get a continuous beep for as long as the button is pressed. The manual troubleshooting sections says this is case "E: maximum closing collisions detected". I have checked and rechecked the gate for easy running and I have set the load setting to maximum (5 beeps). I have even swapped batteries between the two units just in case. Resetting by powering off AC and opening/closing the manual override several times has not helped.
Can it be that the PC board is faulty? Is there something else I can check or do before I call in the repairman?
Thanks for any help!
