JohnJuniorV3
- Dec 21, 2011
Hi guys,
I wanted to know if anyone is familiar with the regulations surrounding CAT6 cable and DC cabling and whether or not it would be okay if they lie next to each other -can they also be in the same conduit?
Currently busy with the solar installation and the team installing have hit a bit of a snag and I am wondering if I am going to have to remove my ethernet cabling to make way for the cables from the solar panels to the inverter.
Edit:
Problem solved, staying far away from the ethernet cables. Fkn dumb idea.
For interest sake though, anyone know the minimum distance and regulations for SA? I know they differ per country and is dependent on the CAT cable type.
Edit:
