Ethernet Powerline Wireless Adapter
Look at the network shops, like Uniterm Direct, Scoop Distributions, Miro, etc.
Some PC shops might sell them too, like Prophecy Shop.
Please just take note that I haven't looked if any of these shops that I've mentioned is actually selling these...
Esquire had some decent/cheap ones for around R200, but I dont see it on the site or pricelist anymore. Actually wanted to buy them and then they disappeared
These aren't as quick as ethernet - but not as slow as wifi G - right?
So moderate speed?
they are supposed to be able to push around 150mbps, but depends on the wiring in the house etc. Reliable speeds are in excess of 50mbps
Will they work if it is used in 2 houses on the same premies, but with seperate power circuits ( DB boards) ?
If the houses on that premises are on the same phase, then there is a chance that it will work, but I can't guarantee you that it will. You'll have to ask one with experience on this field.
