Expected Speed?
mothersruin
Still new to this game. I'm using Netmeter, but seldom get readings higher than a maximun of 36 KB/s. Now I'm on Telkom's Downstream speed of 192 Kbps. Is what I am getting right (average?), or should I give them a call?
Its much better than average! DONT CALL THEM! they might fix it then. On a 192 line the max you should get is 24KB/s although the norm is bout 20-22 KB/s
yeah, lots of people on 192k get close to 384k speeds, lots of people on 384k get close to 512k speeds.
definately don't call them, count yourself lucky! :)
kbps and KBps... the old confusion they should really rename one of them or get rifd of one. kilobits (lowwercase) are 8 times more than KiloBytes, and are used to discribe a internet connection's speed when advertised, but kiloBytes are mostly shown when you download from your PC.
nGAGEd55 said:
just sucks that no-one gets 1024 speeds on 512 :(
Neither do you get it on 1024. So the best bargain DSL still is 384
just remembered that thedoc had a thread where he and someone said they both get 1024 speeds on their 512 lines, lucky bastids :(
...Yes I remember those good ol days...:p :p
Icaris said:
:eek:
Ummm i don't think so. More like KiloBytes are 8 times bigger than kilobits. :D :D
In Quanties you are right,... 1 Byte = 8 bits... but on speed, bits are the bigger number
192kBit line = 192/8 = 24k Bytes... throughput is the key, not quantity.
and 4 bits is a nibble
