I have a wireless router (Gigabyte BN49G) router that connects to a D-Link DSL modem and supplies broadband to the rest of my network. This arrangement works well except that the range is not sufficient. When I am upstairs with my laptop (wireless router is downstairs), the signal is really weak and is sometimes dropped. I ordered an indoor omnidirectional 5db antenna but unfortunately this did not improve the situation.
I have read on the internet that I can use a second wireless router on the network to extend the range. Do I have to connect it using a LAN cable or can it be configured to use a wireless connection between the two routers? Any suggestions on routers that work well? If connected using a LAN cable, do I have to use a crossed over cable or can it be straight?
Cobus
Cobus
