Has anyone used this device to couple an external antenna to the Huawei E1752?
My connection speed could be better with improved reception, wondering how effective capacitive coupling is and whether its worth the expense.
Agreed, rather use the ADPT-026, the ADPT-024 was designed to go on the back of a mobile phone.What about this one? I'd rather use it.
http://www.poyntingdirect.co.za/pADPT-026/Adapter-cable-for-all-USB-Modems---SMAf.aspx
Yes it does:It doesn't say this device works on the 900Mhz band that Cell C use.
The ADPT-024 was in fact specially engineered for 3G band, but it is designed to work for the two voice bands (900 and 1800 MHz) and also the UMTS band (2000 - 2200 MHz).
51% of what? Rather quote the signal strength in dBm, see here.Currently getting 51% signal strength.
