aleksandar
- Jun 14, 2014
Our inverter and batteries are installed in pantry which is around 2.5m2, I keep door open but I can feel heat build up closer to the ceiling especially when inverter fans are on (sunsynk 8kW).
So I was wondering if I should install ceiling fan to extract hot air and "pull in" colder air.
On hot days it might work few hours and I would prefer ones that spin slower.
Any suggestions, good or bad idea?
Are temps below ok?
Are temps below ok?
