Fastest speed possible?
P3wP3w
Sandton
I was just wondering which would be the highest speed my line will be able to sync at?
I don't quite know which values to use when using those online calculators, so I have included my modem statistics:
Modem Status
Connection Status Connected
Us Rate (Kbps) 128
Ds Rate (Kbps) 384
US Margin 15
DS Margin 14
Trained Modulation ADSL_G.dmt
LOS Errors 0
DS Line Attenuation 48
US Line Attenuation 31
Peak Cell Rate 301 cells per sec
CRC Rx Fast 334
CRC Tx Fast 2
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
(I think I may have put this in the wrong section)
Thanks guys :)
should get 8mps or 4mps, but your margin looks pretty bad for 384, as will drop when you go to higher line speed, which can cause problems.
Thanks, seems like I'll just have to give it a try and take it from there.
