Fiat Strada bakkie fuel issues
Johan1979
Good day
Anyone that can advise or assist with problems with a Fiat Strada bakkie with fuel pressure problems
Thanking you in Advance
Johan
Good day
I am based in northern kzn but any advise is welcome please
I am at wits end with this vehicle and dont know what to do any more
Good day
Did you change the fuel pump and filter? Also checked the mesh screen in the tank?
Good day
New fuel pump
New injectors
New fuel pump relay
New fuel rail
Tested fuel pressure at +- 3 bar
Fuel is there
Spark is there
No vacuum leaks
Starts and idles for 2-3 seconds then cuts out
Immobilizer tested - no issue there
Good day
New fuel pump
New injectors
New fuel pump relay
New fuel rail
Fuel is there
Spark is there
No vacuum leaks
did you buy the pump from Motus or is it an aftermarket ,what was the pressure on the old pump ?why did you change all those parts ,what are the DTC codes .which engine is it .need info to maybe help .and Edit did you maybe fit non fiat spark plugs ?
Good day
New fuel pump
New injectors
New fuel pump relay
New fuel rail
Fuel is there
Spark is there
No vacuum leaks
Hi
Old pump packed up but was also 3.0bar before it packed up
Changed pump due to old pump not working and bought original pump
Fiat Strada 1.2 8V (178B) engine
Good day
New fuel pump
New injectors
New fuel pump relay
New fuel rail
Fuel is there
Spark is there
No vacuum leaks
How much has that cost so far?!
Looks like you have been trying the “throw parts at the problem“ troubleshooting technique, which sadly typically doesn’t do much other than drain your wallet.
Hi
is it supplied by Motus (the pump assembly)(i can allmost guarantee you if its not a fiat pump ass. it wont work,what make is the pump ) .if i remember Strada is 3.5 bar and the regulator is in the pump ,no filter to change in the assembly its self cleaning ,do you have the blue id card for the vehicle ?EDIT sparkplugs ? what are they have you changed them .edit edit what codes come up with the DTC reader ,did you use a china reader or an emulator unit
Really stupid question. Did you check for water in the fuel tank???
Hi there
Thanks for all you suggestions so far ..,
Quick question.,,what type of pipe would be used between the fuelpump and the feedline fitting inside the fuel pump housing.
I see a hard type of plastic pipe that is heat shrinked onto both he fuelpump and the housing.,
And its also flexible to move with the springaction inside the housing..
Any alternative to this as i have used normal fuel pipe but it does not hold the pressure and blows off on the fuel pump side
Hi there
ok ,so you want people to answer your question,but you refuse to answer members question ,so you bought an aftermarket part and now it doesnt fit right .you just blew money on things from a aftermarket seller ,now it doesnt work .See it everyday .good luck .
I did not ask for any snotty remarks....if i buy an aftermarket pump its my problem.....my question was purely with regards to the pipe
But sorry you wasted your time in replying with such a shitty remark...go blow yourself
Definitely a good way to get free advice on a forum, maybe 2 more of these kinds of posts and someone will tell you what the problem might be
Hi
oh but here you stated you bought an original pump ,so before you get on your high horse ,you spoke kak ,lied and refuse to answer questions ,i could have helped you if you had been honest from the start .i guess ill just blow away .good luck with what you have purchased hope you find a solution .Edit ,i forgot ,stay off youtube your solution isnt online videos .
I wonder where he bought the fuel pumb? I could use the help with my Strada.
more bitching than fixing going on in threads nowadays. :rolleyes:
