OK so your body coporate has been given the green light to install fibre in the complex Vumatel install fibre My question is if in my apartment I want to change from Vumatel to Open serve Is this possible? Do I need a new and seperate fibre installation or can the existing fibre connection in my flat be re routed to Openserve
With Vuma you can use almost any ISP incl Telkom
Openserve isnt an ISP. They are a NOP like VUMA
If Vuma have installed fibre to your building then that fibre probably belongs to them
The network from the Vuma node to your apartment may or may not belong to Vuma
If your body corp owns the network then they could add an openserve node
If Vuma own the network then the answer is No
BUT - Depending on the age of the building it is likely there are Telkom ducts in the building (to carry the copper)
Telkom would be entitled to use those ducts for fibre
SO - The question is - Would Openserve do it? If they have to go to a lot of cost to serve you only then probably NO... If they can get more then YES
BUT it is likely the Body Corp would make it hard for them... but couldnt stop them
