Some advice /clarity please.
My FNO on installation, installed a 'fibre termination' box where they spliced the fibre line to female connector plug wherein you plug a cable which connects to their ONT box.
Their technician informs me that on new installations they don't use the 'fibre termination box' anymore, they term
inate fibre and plug it directly into ONT.
Is this better - should I have mine removed?
The thinking being that there are less connections in the chain. Would this give you better Internet, speed etc?
Or should I leave it as is?
Appreciate your help/advice
inate fibre and plug it directly into ONT. Is this better - should I have mine removed?
