Hi all
First post on mybroadband, so go easy!
I have recently upgraded to a fibre line with Afrihost & Frogfoot & I am having major problems with my connectivity.
The problem in a nutshell:
- When I connect a new device, I am prompted by an Afrihost Clientzone popup (on my phone & laptop) to log in to clientzone (this happens every single time). This DOES allow me to access the fibre connection.
- Every time I connect a new wireless device, the connection drops from the device I was initially using, making it possible to only be connected to one device at a time.
I am a complete novice when it comes to this kind of thing, so I don't know if its a router setup issue or not.
I have contacted Afrihost countless times, with no concrete answer/solution to the problem. It seems as though this isn't a common issue.
So, is this something that has happened to anyone else? Is there an easy fix that I am missing?
Thank you in advance
Brad
Brad
