Firefox help
PoiZoNouZ
Bryanston
I'm running Firefox (latest version) with Flash and Java installed, certain pages, like www.firewood.co.za display fine, but there are links on the left, cant click on any of them? In IE6 or 7 it works perfect. Also on www.defy.co.za all the links are bunched over each other cant click on anything?
I move the mouse over the links, does not change, and when I click it nothing happens.
That sometimes happens when websites are not coded correctly. Happens with the telkomsa website too: the link to the usage tracker doesn't work...
My advice is to install the IE tab extension, so that whenever you come across a site like this, you can view it in IE without leaving Firefox.
https://addons.mozilla.org/en-US/firefox/addon/1419
It will place a little firefox icon in the bottom right corner of FF, when you click on it, it will change to an IE icon, and render the page using IE.
HTH
