Hi ProAsm.
I have done a test with the following info:
Can you please let me know what you think about it?
Josandre.
Hostname:
IP address: 66.18.86.14
Resolve/Reverse Lookup:66.18.86.14 resolved to myw-stp-66-18-86-14.sentechsa.netDNS Query Results:myw-stp-66-18-86-14.sentechsa.net. 10800 IN A 66.18.86.14sentechsa.net. 1734 IN NS ns2.mailgate.net.sentechsa.net. 1734 IN NS ns1.mailgate.net.ns1.mailgate.net. 123708 IN A 196.38.110.1ns2.mailgate.net. 123708 IN A 196.38.110.2WWWhois Results:Connecting to whois.crsnic.net...NOT FOUND: No match for myw-stp-66-18-86-14.sentechsa.net
Whois Server Version 1.3
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to http://www.internic.net
for detailed information.
No match for "MYW-STP-66-18-86-14.SENTECHSA.NET".
>>> Last update of whois database: Wed, 9 Jun 2004 08:17:22 EDT <<<
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar. Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability. VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
IP Whois Results:Connecting to whois.arin.net...
OrgName: InfoSat (Pty) Ltd
OrgID: IFST
Address: 160 Jan Smuts Avenue, Rosebank
Address: Johannesburg, Gauteng 2196
City:
StateProv:
PostalCode:
Country: ZA
ReferralServer: rwhois://rwhois.infosat.net:4321
NetRange: 66.18.64.0 - 66.18.95.255
CIDR: 66.18.64.0/19
NetName: INFOSAT12-ZA
NetHandle: NET-66-18-64-0-1
Parent: NET-66-0-0-0-0
NetType: Direct Allocation
NameServer: NS1.MAILGATE.NET
NameServer: NS2.MAILGATE.NET
Comment:
RegDate: 2002-11-22
Updated: 2004-01-15
TechHandle: AR756-ARIN
TechName: Roussos, Angelo
TechPhone: +27 11 721 3800
TechEmail:
[email protected]
OrgTechHandle: AR756-ARIN
OrgTechName: Roussos, Angelo
OrgTechPhone: +27 11 721 3800
OrgTechEmail:
[email protected]
# ARIN WHOIS database, last updated 2004-06-08 22:38
# Enter ? for additional hints on searching ARIN's WHOIS database.
Checking Port 80...Port 80 does not appear to be open.Ping Results
ING 66.18.86.14 (66.18.86.14) 56(84) bytes of data.
64 bytes from 66.18.86.14: icmp_seq=1 ttl=111 time=993 ms
64 bytes from 66.18.86.14: icmp_seq=2 ttl=111 time=468 ms
64 bytes from 66.18.86.14: icmp_seq=3 ttl=111 time=542 ms
64 bytes from 66.18.86.14: icmp_seq=4 ttl=111 time=583 ms
64 bytes from 66.18.86.14: icmp_seq=5 ttl=111 time=597 ms
--- 66.18.86.14 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4030ms
rtt min/avg/max/mdev = 468.373/637.097/993.823/183.918 ms
Traceroute Results: 1 63-217-30-94.sdsl.cais.net (63.217.30.94) 0.362 ms 0.272 ms 0.351 ms
2 uunet.pos1-2.cr02.frf02.pccwbtn.net (63.218.15.10) 120.133 ms 121.660 ms 118.247 ms
3 so-0-2-0.TR2.FFT1.ALTER.NET (146.188.6.113) 118.510 ms 121.330 ms 119.317 ms
4 so-1-0-0.TR1.LND2.ALTER.NET (146.188.8.181) 131.347 ms 132.923 ms 133.796 ms
5 so-5-0-0.XR2.LND2.ALTER.NET (146.188.7.229) 113.166 ms 110.493 ms 109.088 ms
6 pos3-0.cr2.lnd5.gbb.uk.uu.net (158.43.233.245) 130.755 ms 131.921 ms 134.828 ms
7 fe8-0-0.gw13.lnd5.gbb.uk.uu.net (158.43.157.141) 307.492 ms 272.284 ms 200.207 ms
8 Internet-Solutions-gw.customer.ALTER.NET (146.188.58.162) 131.696 ms 130.921 ms 130.727 ms
9 168.209.247.158 (168.209.247.158) 131.955 ms 166.990 ms 136.036 ms
10 168.209.100.30 (168.209.100.30) 106.991 ms 106.027 ms 106.373 ms
11 168.209.0.85 (168.209.0.85) 352.866 ms 353.281 ms 353.254 ms
12 isl.nmszone.is.co.za (196.26.0.3) 360.302 ms 353.089 ms 354.833 ms
13 168.209.18.62 (168.209.18.62) 353.093 ms 353.225 ms 352.402 ms
14 gige-0-0-21.rtr-core4-stp.infosat.net (66.18.65.222) 357.949 ms 359.175 ms 360.633 ms
15 66.18.65.105 (66.18.65.105) 368.591 ms 366.862 ms 364.882 ms
16 myw-stp-66-18-86-14.sentechsa.net (66.18.86.14) 653.761 ms 584.994 ms 695.771 ms
Related Links:
SG Broadband Tools
SG TCP/IP Analyzer
SG Security Scanner > Scanned Ports > Commonly Open Ports
SG Speed Test
SG Network Tools
SG Bits/Bytes Conversion Calculator
Buy Broadband
