Hi, wanted to ask some questions:
1. I have bootloader 5.0.1.27t and firmware 5.0.1.66c, will this work fine? if not, how or where can i get both versions of the bootloader or/and firmware?
2. I originaly had firmware 5.0.1.27t on my modem, upgraded to 5.0.1.66c and then to 5.0.1.68m. After a couple o minutes i thought i was having a problem with the connection and downgraded to 5.0.1.66c again. I dont have the 5.0.1.27t firmware or i would compare with the others.
3. Can someone get us a site or something with all firmware once and for all.
4. I tried to install the modem on linux, im using slak with a 2.6.x (latest) kernel. It seems it's there by default, but when i try to use the modem it stays at "initializing modem" forever! (yes, i recompiled the kernel with that driver). Just one question, MUST i select the driver as a module or can i compile it directly into the kernel, and why?
Thanks for all you guys that keep beating it up!
alex
alex
