Fix routing issue
cavedog
PTA
Hey guys I tried everything but can't get Telkom to fix the routing issue they have to Vox.
My VOIP provider Greydot uses a Vox server and the connection is routed to the UK and then back to Vox.
Testing the same ip with Afrihost on adsl gives 35ms ping while Telkom LTE gives about 250ms or so as it goes to the UK and then back.
IP in question is 41.79.79.10
How do one fix an issue like this.... :confused:
voip on lte not recomended...
Says who? Works perfect even better than adsl. It's a routing issue. When I use Freshphone or Mweb Talk the latency to the sip is like 25ms only this server with Greydot the connection gets routed to the UK.
That said it works fine I did not notice any issues but still a routing issue that needs to get fixed from Telkom's side. Not sure why they won't peer with Vox locally....
