Flash Ipad -- possible ?
scoobydoo101sa
Hi guys
Basically have a few ipads that users dont need anymore but can remember their passwords to the dam ipads
Where can i get them reset to factor defaults ?
thanks
Hi guys
thanks
They will be iCloud locked if you don’t sign out of your Apple ID. The iPads will be unusable then.
If you can remember the email you used you can click on forgot password and you might have luck then.
If it only has a passcode with no Apple ID a factory reset might do the job.
dam so these things are useless without pin codes or apple ids
use them for door stops ?
yeah not gonna be easy
we have an iMac at work that is a doorstop coz the guy that left a few years ago cannot remember his password
