cjoliver
Has any else been having issues running the latest fnb android app on a bootloader unlocked device?
I have confirm with about 6 devices that if you have an unlocked bootloader, then the FNB app doesn't open and you can't install it from the android play store. Factory reset and lock the bootloader and boom, it works again.
You can download the latest APK from a mirror site, but it only flashes the splash screen and then disappears again if started.
So far the Devs are not answering my emails.
Wanted to find out of anyone else is having the same experience?
Currently I'm running version 7.8.0-50 (85) hce as this seems the be the last version that will start on an unlocked bootloader.
CJ
CJ
