Forcing output through a specific 3.5mm jack
_Maximus_
Hey guys
For some odd reason the back 3.5mm green output jack - the one you usually plug your headphones into - has stopped working.
Is there any way I can reroute normal stereo output to another jack port? Like the black, orange, blue port etc..
Ive had some issues with getting the front panel to work, so I would think it would be easier just reroute the stereo output to another port.
If this idea is absurd, feel free to tell me! Im not much of a sound guy so please excuse my lack of technical wording here :)
Link to my motherboard if needed: http://www.jetway.com.tw/jw/motherboard_view.asp?productid=485&proname=HA05-GT
Thanks in advance!
Hey guys
Thanks in advance!
Reinstall drivers first...
YES! It works with new updated drivers.. Duno what issues the old set had but theyve been fixed.
@xera - Thanks for that awesome walkthrough. It was going to be my second option, but the drivers are hassle free. Hope you got your output on your P67 fixed!
Great stuff. However new drivers did not work for me. But I managed to map the pins correctly in the registry, so mine is working fine :) Both Green + Black = front speaker out :)
Great stuff :). Glad I could help :)
