Ford Figo Gearbox Dissenged
Antburns
Hi All,
This morning while driving my Figo I geared down and the gear lever went "floppy".
There was no grinding or crunching but now I can't get into any gear. No other issues with the car.
Can anyone suggest what the issue might be and what could be done to fix it?
I tried to see where the gear lever engages with the gearbox but could not spot it.
Thanks In Advance.
Thanks for all the links Champ. Had a look and definitely seems to be the issue.
Will check it out and give some feedback.
As per the video you posted. A rubber bush trimmed down to size, some washers, a grub clip and a little grease and I am back on the road.
Thanks again Champ.
