Hi guys, first time poster
My corsa bakkie 1.4 2001 developed an issue two days ago where at first it would struggle to get into first gear ( wouldn't engage and would not deliver power unless i put it into the reverse position by lifting up the tab) and now is stuck in reverse with the gear stick being unable to engage any of the gears and flops around. I did some research and found that a common problem that may fit its description would be an issue with the gear selector rod being damaged but I inspected it and found it not broken although the rod (plastic) does swivel on the ball joints which im sure is normal. Is there anyone who has had the same problem or can offer me any advice? the engine was serviced a few months ago as the gasket had been replaced so I'm not sure if the assembly may have anything to do with it (still under guarantee).
tl;dr bakkie not able to change gears, gear stick flops around, stuck in reverse gear, cant be put into neutral as it still reverses.
Thanks, if a video demonstration would be better to understand the problem I would be happy to post one.
