Gadwin Printscreen Pro
pedruid
Port Elizabeth
:wtf: I had to replace my motherboard and i3 as the board failed. I use Win 7 and now Gadwin says it's stopped working, its the same with iTunes.
Anyone out there who an shed some light on the problem?
You will have to clarify a bit more. Did you do a fresh install of windows or is it the old installation?
Sorry for the late reply but it was a fresh install. I'm also having a problem with iTunes as it refuses to load and on the problem solver it says "Fault Module Name: CoreAudioToolbox.dll".
The Guy who repaired my machine has I believe loaded a newer driver for the graphics card and I'm too bung to try what they recommend.Downloading an old driver.
When I try to load Gadwin I get this "Fault Module Name: PrintScreenPro64.exe"
Any further advise will be greatly appreciated.
I would fully update windows then reinstall those programs.
