Gas Heaters ...
The_Traveller
I got one of the BOSCH gas heaters for 10 years now, and its working well. I need to buy another one ( or two ) but cant seem to find them anymore, but there's so many others available. But I also hear horror stories ...
What's a good brand to choose ? I see Builders and Makro have some specials ... Any advice is appreciated.
I've got that Goldair one on the left, works well enough.
Also looking for a gas heater, saw a Goldair dual heater (gas and electricity) at House & Home for R1299 and am tempted.
I have known Goldair for some time now and I wouldn't mind it, would be nice to get options from members here.
I've had a Goldair, just like one on the left for about 2 years. Very happy with it.
Goldair is OK. They are pretty well made. I've never [-]had a problem[/-] been burned up in a ball of gaseous flames.
Delongi is a good make: http://www.takealot.com/delonghi-gas-heater-4200-w-ir3010/PLID27882497
Price around though - I am fast finding out that Takealot's 'specials' are not always the cheapest out there!
I can't remember the brand but my gas heater has got a low-speed cold fan on it - so the gas flame creates the heat which rises and then the (cool air) fan blows it out into the room. It makes quite a difference compared to not having the fan on. If you run out of gas then you are also able to operate it like a regular fan heater by switching on the electric heater.
The technology is practically generic and commoditised. Gas equipment is tested to a very high standard due to the possible disastrous and immediate effects should it fail. The only differentiator is looks and the firing/start mechanism. You can always fire them up easily with a match if the electric spark goes. The greatest danger is using the heater in unventilated rooms (burning gas uses oxygen rapidly) and leaving them unattended. Something in the room catches fire from being too close. The gas bottle heats up. Kaboom!
One tip with these panel heaters, switching on all 3 panels will empty a 9kg bottle in a couple of nights, try to use it only to heat up the room quickly then switch to 1 or two panels to maintain the heat.
The cheapies i.e. the PLATINUM brand, has exploded on me. Therefore I have resorted to buying heaters from those who emigrate, typically the old ones made in Spain.
Please elaborate. I value my life.
That's one of my worries, so Platinum brand is a no no ... Alva sounds good as well as Gold Air ...
It is in my garage for inspection for anyone who wants to see.
Last winter, I turned it on and lit it, and it blew a fireball from underneath to the top which burnt my hand, so I took it outside to relight it, and it was shooting flames out the bottom. Nothing ever happened to it and I cannot find the leak. Cheap chinese kark is what it is.
I've got the Alva, very happy with it, I've seen the Logik from Game and it looks exactly the same, my guess would be that they just re brand them...
I would just go for which ever is cheaper...
*bump* Anybody know of a good gas heater? I want one! I'm also not looking for the cheapest, I want something that won't explode lol.
Ok, so in case it helps the next person, here's my non-exhaustive findings:
First bought a Alva 9kg-cylinder gas heater from Builder's Warehouse: they're on special for R899 currently. Builders also sell Afrox 9kg gas cylinders for R540, so picked up one of those too.
Got back home to discover that the Alva requires some serious assembly: the base with the wheels isn't connected to the top bit, so that takes a total of eight screws and some very fiddly washers to get secured. Not super easy at all, so not a great start to the experience. What was worse is that once it was all set up, we couldn't get it lit: the pilot light would fire but it would only stay alight for as long as the gas valve was kept pressed down (no matter how many times I tried it or how long I held it). Apparently this is a common issue with these heaters.
Cue another trip back to Builder's and they refunded my heater. They told me another guy had brought back an Alva heater that very morning with the same problem but they'd managed to get it started, but because I'd left my gas bottle at home they ended up just accepting our story and gave us the refund.
That left our choices at Builder's down to three: 1) Buy another of the same Alva; 2) Buy a Gold Air heater (as soon as I saw it was distributed by Nu World I scrapped that idea); or 3) Buy a Megamaster heater.
I opted for option 3: the Megamaster heater is also made in China but its distributor has a local presence, it cost R100 more than the Alva (i.e. R999), and it seemed to have a better build quality.
The latter point was confirmed when I got home: the base is already attached so all that's required for assembly is screwing four screws into the back-plate (much easier). Connected everything up, gave it the gas and hit the starter and ... the pilot died immediately (same as the Alva)!!! On my third try, however, it started working (PHEW) and its running like a charm on max now (*really* nice and toasty). I think there's a trick with having to hit the ignition button twice quickly to get the pilot to stay on, will experiment.
Soooo ... hope that helps somebody this winter :) If I can get over my fear of gas, I reckon anybody can. There are a LOT of scary warnings in the instruction manuals too, but doing the 'leak test' with soap gives you a measure of confidence.
Keep warm guys n gals!
:D
It's a knack you soon pick up, I hold the gas selector down in the 1 position for a slow three count and then hit the igniter button. If (not when :) ) it lights I continue holding the selector down for a ten count and release.
