Gas Leak Detector / Alarm
Dean
Has anyone looked into or used gas leak detectors/alarms that are available locally, similar to smoke alarms?
For propane/cooking gas, for home use.
Just looking for something available in SA that sounds an alarm if the gas is detected in the air.
Bonus points if it integrates into a Paradox alarm system.
Not looking for a smoke/carbon monoxide detector, but if you've used one that has both functions built-in, that could work too.
TIA
Any luck? I'm using a battery operated non-smart gas detector.
Saw this. Perfect for me as I am invested in the tuya smartlife ecosystem.
This is made for campers but should work.
Perhaps an overkill for your use ( includes alarm sensors as well).
From the website :
A standalone caravan alarm system remote controller from a mobile phone that monitors two LPG detectors, 4 intruder alarm zones, and an ultrasonic scanner. Reporting is by a local buzzer, mobile phone screen messages, and SMS to a designated SMS- capable device.
R273
R273
Not smart one?
I have this one but thinking of the smart version as it has gas and smoke detection if I recall correctly. Also at geewiz.
Not smart one?
This one ? Gas and CO2 detection. R595
